Announced in March 2015 and released April 10, 2015, the Galaxy S6 Edge is the curved-screen version of Samsung's newest flagship smartphone.
222 Questions Показать все
What layers does the S6/S7 edge display have?
Someone asked me to replace the glass on his S6 edge. Not having done this before, I watched some videos on how it's done. Some show the glass coming off with a film below it, others show the glass coming off without the film.
I started removing the shards from the top and with them the film. Before continuing, I want to know: Does that film matter?
Отвечено! View the answer У меня та же проблема
Это хороший вопрос?
по рейтингу 0
Добавить комментарий
2 Ответов
Выбранное решение
Ciprian R , I believe the film you are talking about is the adhesive, it is like very thin 2 sided tape and must be removed from the display before you install the new glass/digitizer. I think what you see in the video's is sometimes the adhesive sticks to the digitizer glass, sometimes to the lcd and sometimes on both. Good luck.
Был ли этот ответ полезен?
по рейтингу 3
Комментарии:
I've seen people replace the glass without removing this film. They removed only the shards.
от
Are you meaning the clear "film" that is sometimes still left when removing the glass? If so, the film is usually removed with the screen if it was heated and pried of correctly but if the film decides to stay on the screen then you can usually pull it off with a little elbow grease. The film is just a bottom layer for the screen that can be sometimes tedious to get off but is replaced when you put the new glass on. The film really doesn't matter in any case but removing it would be more professional and the glass may have an easier time staying on the phone with this layer removed.
по рейтингу 0
Комментарии:
I came across a gold 'film' beneath the digitizer that is definitely not any form of adhesive but moreso like gold foil paper ...do you know it's function and if I should remove before screen and digitizer replacement? Thanks
от
@Garr, From what I've read when researching replacing my screen and other parts of galaxy phones (I have 5 different ones), the gold foil you refer to is a signal booster. It's merely a piece of a specific type of aluminum that helps to make the network faster. Someone please correct me if im totally off base.
от
Добавьте свой ответ
Ciprian R будет вечно благодарен.
Просмотр статистики:
За 24 часа: 3
За 7 дней: 10
За 30 дней: 25
За всё время: 1,439
