The HP Officejet 6600 Inkjet Multifunction Printer is a 4-in-1 device that can print, scan, copy and fax.
62вопросов Показать все
Why can't I print a card sized 4.9 x 9.8" using custom settings
why can't i print a card sized 4.9 x 9.8" using custom settings, i get a response that the printer does not support that size despite printing it on several occasions previously?
Это хороший вопрос?
Оценка 0
Добавить комментарий
2 Ответов
How big an area are you trying to print? You may need to use the next smaller paper size, that should work. The only down side here is the larger margins.
Был ли этот ответ полезен?
Оценка 0
You should be able to print that size, what may be going on is that the paper width needs to be 4.5" and length set to 9.5", you may have to change orientation from Portrait to Landscape.
Оценка 0
Добавьте свой ответ
Denise будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 12
За всё время: 48
