Repair information for the 6th generation iPod nano. Released in September of 2010. Model Number: A1366.
iPod Nano 6th Generation LCD Adhesive Recommendation?
Hi all,
I just replaced an LCD on my nano. Looks good. Works fine. Only problem I am experiencing it with the adhesive. I bought the custom precut adhesives from ebay but they seem a bit too narrow. When placed on the ipod they seem to sit a little below in the recessed area so the LCD doesn't make enough contact with it to stick.
Anyone have any adhesive recommendations?
Thanks!
Это хороший вопрос?
Счет 2
Добавить комментарий
2 Ответов
Наиболее полезный ответ
@gob15 , Christopher, The 1st link below shows the recommended tape to used in the ifixit disassembly guide 2nd link. Good luck.
[связанный продукт отсутствует или отключен: IF145-283]
iPod Nano 6th Generation Front Panel Assembly Replacement
Был ли этот ответ полезен?
Счет 3
4 Комментариев:
Thanks for the links. Were there other options for the tape? The LCD I bought was the same price as the tape and shipped free! The shipping on the tape is half the price of the tape itself.
из
@gob15 search on eBay for the red "ultra sticky double sided tape", thin, strong and cheap
из
@reecee, @gob15 , Reece, thanks for the input,I believe this is the stuff in the link below.
http://www.ebay.ie/itm/2mm-25M-Ultra-Sli...
из
Thanks. That tape does seem thinner than even the pre-cut adhesive being sold for the nano. I can give it a try though and see how it works out.
из
Hi Christopher, also absolutely vital is to clean all surfaces with alcohol before trying to stick down. Also, I found that leaving the backing tape in place on the cable side until you have got the screen ribbons tucked in, really helps. Good luck ☺☺
Счет 1
Добавьте свой ответ
Christopher Cross буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 0
За последние 30 дней: 12
За всё время: 1,586
