Pocket-sized GPS receiver with a 4.3" touchscreen and Bluetooth.
It's not turning on
I have previously replace the battery front screen and updated the maps & it was working fine, but for some reason it won't power on. Left it on charge but it seems like the charge may not be registering with inside battery. I can see the green light on but nothing coming on. I left the device working in the glove compartment of my car so not sure what's wrong?
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
Raja Minhas , If you are not sure the device is taking a charge try another compatible charger to see if that is the issue. If charger is good remove the battery(1st link)below and see if it is fully charged use a DVOM, if battery not charged could be a faulty battery or charge port issue. Blow/pick out any dust/lint/etc. from the charge port and look for bent pins and straighten carefully with a tooth pick. If battery is OK and charged try a reset 2nd link will tell how. If device happens to be under warranty return for repair/replacement/refund. Good luck.
https://www.youtube.com/watch?v=NcbebExQ...
https://www.gpspower.net/tomtom-tutorial...
Был ли этот ответ полезен?
Счет 2
Добавьте свой ответ
Raja Minhas буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 2
За последние 30 дней: 8
За всё время: 475
