Дата выхода 25 сентября 2015 г. Модель A1687 / A1634. Ремонт данного устройства схож с предыдущими моделями, требующий отвертки и инструменты для вскрытия. Доступен в версиях GSM или CDMA; с 16, 64 или 128 ГБ памяти; в цветах: Серебристый, Золотой, «Серый космос» и «Розовое золото».
1041вопросов Показать все
Water Damaged and wont turn on
My iPhone was in my pocket and i fell asleep this is embarrassing but i wet the bed from drinking a lot i guess and i woke up my phone screen was white i could still see the time and everything and swipe but couldn't unlock it with my code i left in rice for the rest of day now it wont turn on at all. Is there anything I can do?
Это хороший вопрос?
Оценка 0
Добавить комментарий
2 Ответов
Наиболее полезный ответ
Arop A , The rice would have done very little to help your phone as it is not a very good at liquid absorption, make sure to clean the rice out of all nooks and cranny's. Stop charging or powering up your device until the liquid damage is addressed correctly, as you could be shorting out components inside the phone. You really should take care of the corrosion that is happening inside the phone from the water damage as that could be your problem. A tear down link for your device Link #1, disassembly guide will enable you to get inside the phone to remove the damage/corrosion caused by the liquid. Use the 2nd link as a guide/instruction on how to clean/repair the device from liquid damage. After this you will be able to power on the phone and see if further damage has to be addressed. Good luck.
Разбираем iPhone 6s Plus
Electronics Water Damage
Был ли этот ответ полезен?
Оценка 2
Putting the phone in rice probably didn't help. Some components may be shorted internally, so you should avoid using the device or charging it to prevent internal damage. From your description it sounds like there may be issues with the display, as well as more extensive damage.
Below is a teardown of the phone, and also some guides to help with liquid damage to phones.
Repairing iPhone Liquid Damage
iPhone Изображение
Инструкция
Сложность:
Сложно
1 - 2 hours
iPhone 6s Plus Изображение
Инструкция
Сложность:
Модерировать
Оценка 1
Добавьте свой ответ
Arop A будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 1,280
