leaking water out bottom of coffee maker
my keurig k40 is leaking water from the bottom
Это хороший вопрос?
Это хороший вопрос?
There are several possible causes.
The easiest to check and fix is that the holding tank is cracked and leaking.
Its also possible that the needle is clogged up with grounds, you can use a paperclip to clean out the needle.
It could also be that something is broken inside the which is difficult to diagnose without taking it entirely apart.
Был ли этот ответ полезен?
The bottom needle broke off with the plastic it it modes to.
Is there a replacement part available?
За последние 24часов: 2
За последние 7 дней: 2
За последние 30 дней: 9
За всё время: 4,545
