Drop on back bootloop, repair shop fail
I'm currently travelling, and whilst in Cuba I proceed to drop my phone flat on its back which causes it to bootloop. This happened to me in Canada as well, where I opened it up reseated the display cables and was good to go, when I tried this in Cuba, it did not solve the problem. It was and is still in a bootloop on the apple logo and then black.
From research on this site I assumed it was an issue with the battery, so I have taken it to a repair shop where they reseated it and tried a new one, but it failed to fix the issue. It is still in a bootloop.
They gave a load of excuses and no real reason to why it is broken other than my jailbreak my have been the cause, which I find very hard to believe. They then suggest that I try a restore, which I have just attempted to which I get error (9). Which I think means a hardware issue.
If the battery is not the issue, the only hardware problem I can think of is from screwing the wrong screws on the guard of the display cables, would this be the cause? How do I go about checking this and fixing it?
iPhone 5s 10.2
Jailbroken Yalu b7
Это хороший вопрос?
3 Комментариев
Did you try a DFU mode restore?
из Gigabit87898
I haven't, sadly my laptop has died so cannot restore at this point, I will give this a go once i get my laptop repaired
из charlie.smith142
Finally have my laptop up and running and sadly this does not work, DFU restore simply returns the same error 9
из charlie.smith142
