Model A1502 / 2.6 GHz (Turbo Boost up to 3.1 GHz) or 2.8 GHz (Turbo Boost up to 3.3 GHz) dual-core Intel Core i7 processor with 4MB shared L3 cache.
MacBook fan does not speed up causing overheating despite sensors ok
Hi all,
I havean issue with my Macbook pro retina 13 2014:
despite high CPU usage, the fan spins constantly at 1300 RPM, which causes the CPU temperature raise up to 80C.
All temperature sensors seem to work fine and I can manually adjust fan speed as well as it can be changed by MFC.
Also i tried 3 different fans and the situation doesn't change.
I tried to reset SMC, pram and to reinstall the system (was cooling down CPU manually, don't ask how)
Atm i am using MacFanControl to regulate the speed of the fan, but the issue is still present and causing some discomfort, like i can't install new OS because MFC doesn't run during OS installation and i am afraid of overheating.
Despite all components look good, the system doesn't regulate the speed of the fan.
This happened after i heavily broke my macbook and tried to repair it by replacing its aluminium body, its broken screen assembly and its noisy fan (was a bit bended which caused noise).
It is interesting that after i disconnected touchpad the fan was speeding up normally when CPU temperature was raising. The downside of this was that macbook was constantly throttling , CPU usage was 300% and everything was very slow. I had the same symptoms when camera's cable was damaged.
Can anybody help me with this please?
Macbook photos
Это хороший вопрос?
Счет 3
Добавить комментарий
1 ответ
Наиболее полезный ответ
I have a Mid 2012 and a mid 2014 Macbook pro. I use a free app called MacsFanControl. It allows me to control the fan and which sensor triggers it.
Был ли этот ответ полезен?
Счет 1
Добавьте свой ответ
Dmytro буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 0
За последние 30 дней: 7
За всё время: 717
