iPhone does charge when opened, not when closed
Hi,
I replaced the battery on my iPhone 5s. I have done this before without problems.
But now, I have replaced the battery and sometimes it charge, sometimes it does not.
As far as I can see it does not matter if it is on a slow usb, a fast usb, a apple cable of a china cable. sometimes it charges on a slow china, other time a slow apple.
there are some stranges things.... if I open the iPhone, just take out the two screws and lift the screen so that it just pop out the screen from the bottom, the top can be in place and I don't see the inside, the iPhone suddenly charges!! every time.
The other thing is (with the phone fixed together "as usual") when I push the phone with both fingers left and right of the home button (on the white glass) the screen pops up. If I push long Siri speaks to me.
It looks like there is something wrong in the homebutton erea but I cant figure out what it could be.
Это хороший вопрос?
4 Комментариев
just ordered a Lightning Connector. When I replaced the Lightning Connector I will get back to you :)
из André tR
there probably is just a pinched wire straighten the wire out inside the iPhone the put it back together
из Jared Morgan
I replaced the Lightning Connector and it seems to work :D thanks
из André tR
Well now I finally know the cause of charging when opened but not when closed.
Thanks for the follow up.
из Ben
