Samsung's 5th-generation Android-based Galaxy smartphone was released April 11, 2014. Improvements to the phone include a fingerprint scanner, updated camera, larger display, and water resistance. It is available in four different colors; black, blue, white, and copper.
577вопросов Показать все
In boot loop 5 or 6 times then goes black
Hi Guys.
OK i have a Samsung Galaxy S5 which has never had a screen replaced or ever been damaged.
When it was brought in it was just a blank screen the phone is on as i can hear when it rings gets messages ETC it also vibrates too.
I took the battery off so i could restart it it does start up & comes up with the Samsung Galaxy S5 start up graphic then loops sometimes 5 times sometimes 6 then the screen goes black.
When the screen goes black the buttons along the bottom light up fine when activated.
I can't tell if the backlight is on when its black i don't think it is.
Any help or suggestions would be greatly appreciated.
Thanks in advance.
Это хороший вопрос?
Оценка 0
Добавить комментарий
2 Ответов
Наиболее полезный ответ
Hey Kenny, Ive run into the issue before ive found a temporary fix but it only works long enough to pull data off the phone the phone is pretty much screwed
Ive found that heating the proccessor with a heater for 8 minutes at 120C make sure you place the heat gun 3 inches above the chip and heat let cool and reassemble this has worked for me 90% of the time and will pull it out of boot loop for about a hour
Был ли этот ответ полезен?
Оценка 1
1 Комментарий:
Hi Stephen thank you i will give that a go later & let you know how it goes.
из
It sounds like an issue with Android itself, it might be soft bricked. Did you try to flash/install something?
Оценка 0
2 Комментариев:
Don't think so she said she has never had anything done to it
из
Reading it over now, I see what you mean. Sorry, I must've misread the question!
из
Добавьте свой ответ
Kenny Leonard будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 76
