Why do I have horizontal lines down the screen
I have horizontal lines down the screen,the phone is working fine but the lines are annoying. How and what do I need to do to fix it?
Это хороший вопрос?
Оценка 0
1 Комментарий
Mine too. But my mobile fell and later after a couple of days, it over heated after a prolonged video meeting, then horizontal lines appears and are irritating
из
Добавить комментарий
2 Ответов
Выбранное решение
@nitramet ,Trent, Could be a couple things possibly LCD connection has come loose or LCD has been damaged. I will post a disassembly link below so you can get inside the device and check the connections/clean with Qtip dampened with 90%+ Isopropyl Alcohol and reseat connection and try. If display still bad then it is probably a bad LCD. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
https://www.youtube.com/watch?v=j9SmDB12...
Был ли этот ответ полезен?
Оценка 2
1 Комментарий:
Can u plz tell me how I can fix the lines in My phone
из
How do i get the lines from going down my phone
Update (08/26/2018)
Should I turn the phone off and then turn it back on again
Оценка 0
1 Комментарий:
I just faced same problem. Any solution you find out yet?
из
Добавьте свой ответ
Trent martin будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 6
За всё время: 5,162
