Anyway to repair the copper traces on motherboard?
hi to all,
I was trying to replace charging chip on an iPhone 6. In the past I use to solder the laptop and desktop motherboards but nothing this small as the iPhone 6 motherboard.
Anyway, I used the heat gun, some flux, and everything seemed ok but later under the microscope I noticed that there are few round circle pins missing. I probably didn't heat the motherboard enough and while removing chip I probably tore the trace and removed with those small copper pins.
The question is: Is there anyway to repair them? I presume that the where somehow connected to the copper via's inside the motherboard.
Is there anyway to solder/glue them back again?
Update (04/01/2017)
here it is attached, and sorry it is not iphone 6 but iphone 6s. According to the schematic pins are A4 and D4
Это хороший вопрос?
1 Комментарий
Most of the time those are dummy NC pads. Post the image.
из MicroSolderingParts.com
