iPhone 6 Black Screen but it's on & can still receive calls
This is the first time I have experienced with my Iphone 6. After I charged it, when I was answering e-mails the screen turned black. I was thinking maybe it was the battery. But when I try to charge it again the screen is still black and I got surprised that my Iphone is ringing and I can still answer calls and it alarms and I still receive text messages. But I couldn't open it because the screen display is black. I tried to "hard reset" but It did not work. What could be the problem? I did not drop the iphone. The screen just turned black unexpectedly.
Это хороший вопрос?
8 Comments
Hey guys! I just found out that It might be the backlight that's causing my iphone screen black. Can I possibly fix it by myself?
из debrutz
The similar thread you can refer to if you want to reset the LCD connector by yourself.
iPhone 4 is working but screen is black?
из Andy Smith
I just wanted to thank you for this advice! It worked very well! I was listening to a message from my dentist and the screen went black! I have had the I phone 6 for only a year and a half and this is the first time this has happened! Many thanks for your timely intervention as I so needed it! You are a lifesaver!
из Lori Johnson
I had the same problem too but with my iPhone 8. My phone seemed to freeze on the weather app so I hit the power button that is when the black screen wouldn't go away. I had notification sounds and an alarm going off. And could still use siri. I asked siri to open the app that froze but it was extremely slow and then was able to power off the phone then I was able to use it normally.
из Lexi Eaves
I have exactly the same issue. My phone just blacks out but it is still responsive as I can receive calls and it vibrates.
I have to press and hold the part below the camera lens for some time before forcing a restart.
It work temporarily before I have to repeat the whole cycle again.
Did you find a way to fix your phone and how?
из Yung Wei
Показать 3 больше комментариев
