Where can I find a replacement USB charging circuit board for UE Boom?
Due to corrosion, I need to replace the USB port, along with the circuit board attached to it from my UE Boom. I can't seem to find the part anywhere. There are plenty of numbers on the circuit board, but they all seem to be random. I was hoping someone could either tell me where I can find the part, or give me an alternative solution. I'm trying to avoid buying an already broken donor speaker for the part. The board does say that it is manufactured by Logitech.
Here are the numbers:
TP503
TP502
TP501
3613C
E153302
94V-0
USB_1417-002
CN501
Это хороший вопрос?
5 Комментариев
I need to buy this item but i don’t know how
из safimatihullah
Not charging properly
из Kannu Dumka
How to purchase charging circuit board model s-00122
из Kannu Dumka
Anyone just added another port to charge the battery? Then connect direct to the battery
из lyndonjc
@lyndonjc
Doing that may be a bit dangerous because you would be bypassing the battery management circuits which prevent the battery from being overheated or or overcharged whilst charging
из jayeff
