DeLonghi ESAM 3500 hot water/descale problems
Hello,
I received a DeLonghi coffee machine (used one), everything is working fine, makes coffee (soft ones, that is true) but when I press the hot water button the machine doesn't give hot water on the water spout and as well the descale procedure doesn't work.
I opened the machine and I saw that one wire is disconnected from the behind of the machine and the same wire is connected near the water spout nozzle (details in photos).
I want to ask why is that wire disconnected, and what could happen if I will connect that wire ?
Thank you ! :)
Update (04/08/2017)
Это хороший вопрос?
@bondan91 post some more images but zoom out. Give us a chance to see where those parts are situated on your coffemaker. Image one is the right side and image 2 is the back? trying to figure out where those locations are.
из oldturkey03
First image is the back of the coffee machine (left upper corner) and the second image is the front.
Here are more images:
https://ibb.co/hURMgQ
https://ibb.co/nr1nMQ
из Onica Bogdan
