@bo1 the 5 blink error code can have quite a few different causes. Ranging from the T-con board to the panel and few things in between. If you have the original TV remote than try to see if this will work on your set:
1. In standby mode, press the following buttons on the Sony remote:
DISPLAY....5....VOL(-)....TV POWER
2. On the left side are the blink codes. On the right hand side is the error count.
3. Under 005, you'll see three listings... TCON, HFR, and P-ID (panel).
4. Let us know what errors your set shows.
If that does not work on your set, then you will have to remove the back of your TV and check the boards. Try to rule out/in the T-con board as faulty. Disconnect the LVDS cable to the T-CON board, the cable between the Main board and the T-CON board, and see if the error code will change. Let us know what the result is.
Был ли этот ответ полезен?
Проголосовали
Отменить
Оценка
12
Отмена
Scroll through this thread to find the appropriate place for this comment. Then, click "Attach comment to this post" to move it.
32 Комментариев
Had the same problem replaced Pico fuse on Power Supply fixed problem. Fuse is located near top left closer to connector plug . Fuse is & amps marked as L7.
из Bobby Mays
Had the same problem replaced Pico fuse on Power Supply fixed problem. Fuse is located near top left closer to connector plug . Fuse is 7 amps marked as L7.
из Bobby Mays
Hello,
I have a Sony Bravia 40 inch smart LED, model KDL40W652D. When I switch it on, it switches one for few seconds, and then the screen blacks out followed by 5 times red light blinks.
Is there a way to get this fixed… thanks much for your help.
Regards,
Sid
из sid
yes me too facing the same problem
contacted sony customer care and technician visited checked and told its a Tcon board problem
из Sb Basu
my sony bravia model KDL-50W800D
из Sb Basu
Показать 27 больше комментариев
