losing water out of back engine
losing out of back engine
Отвечено! View the answer У меня та же проблема
Это хороший вопрос?
по рейтингу 0
Комментарии:
where in the back is it leaking? Within the bellhousing, above it or the sides of the engine toward the back? How much water is leaking out, how often do you have to replace the fluid? Need a little bit more info to give you a better answer since there are plenty of opportunities for leakage. Thanks
от
Добавить комментарий
Free shipping on all orders over 100 $ or containing a Pro Tech Toolkit!
Посмотрите наш магазин
5 Ответов
Выбранное решение
Have your freeze plugs checked. If the engine has frozen with insufficient anti-freeze there are plugs built into the engine that will pop out to avoid damage to the block.
Был ли этот ответ полезен?
по рейтингу 3
It could also be leaking from the connections to the vehicle's heater core.
по рейтингу 2
I was a Chevy tech for 20 yrs...couple of areas to look.
There could be a connector at the rear of the intake manifold that connects a metal pipe from the manifold to the heater core. Those get corroded over time and can leak.
Also the intake manifold gaskets themselves can leak in that area too.
You can rent a coolant pressure tester from the parts store and pressurize the system to locate the leak.
Hope this helps
по рейтингу 1
thanks. the heater core leakage is probably the answer. My heater is working only on and off. Thanks
по рейтингу 0
If it is leaking out of the back of the engine, it is probably the freeze-out plugs as mayer stated...low coolant will cause the heater to work intermittently or not at all. Check closer before you get the heater core replaced.
по рейтингу 0
Добавьте свой ответ
john будет вечно благодарен.
Просмотр статистики:
За 24 часа: 0
За 7 дней: 1
За 30 дней: 2
За всё время: 921
