Released October 2008 / 2.4, 2.53, 2.66, 2.8 or 2.93 GHz Core 2 Duo Processor
442 Questions Показать все
Battery Access door doesn't close cleanly
What's the best way to to get the battery access door to close cleanly against the front edge? Right now it doesn't snap tightly, but does hold in place.
Отвечено! View the answer У меня та же проблема
Это хороший вопрос?
по рейтингу 0
Добавить комментарий
Free shipping on all orders over 100,00 $ or containing a Pro Tech Toolkit!
Посмотрите наш магазин
3 Ответов
Выбранное решение
Have you had the screws of the other half of the bottom case out? If yes, check if one of the four tiny screws next to the battery bay protudes. They are shorter than the outer screws.
Otherwise a slight push lets the access door snap into place.
Был ли этот ответ полезен?
по рейтингу 2
Комментарии:
+ do the push as you close the latch
от
did you check your battery? it might be swollen....
по рейтингу 0
There's a small plastic piece that fits on one edge of the battery facing the main case. Mine fell off. It appears that it's merely glued to the battery. This piece of plastic holds the battery down enough for the battery cover to close properly. I simply glued the piece back on the the battery and let it set for a while, around 1 hour. Then I put the battery back in and the cover closed properly.
My two cents.
BTW, if you do go to speak to the genius bar, make sure the apple genius is female. My experience has been that males are arrogant, rude, stubborn, and do not listen to you or take the time to understand the real problem. Girls on the other hand, seem to be more knowledgeable, patient, and they listen to the customer.
Again, my two cents.
Mark G.
по рейтингу 0
Добавьте свой ответ
Ross4 будет вечно благодарен.
Просмотр статистики:
За 24 часа: 0
За 7 дней: 0
За 30 дней: 4
За всё время: 1,187
