Shield connector broken-phone won't turn on
Looking for help please.
I have an iPhone 6 that won't switch on.
It connects to a pc via the cable but nothing on screen.
All that I can see wrong inside the phone is that the small flex connector at the bottom of the shield, that takes the home button flex - is totally ruined.
2 previously functioning screens are not firing up on this device.
Would this broken shield connector stop the screen working all together? Or just effect the home button functionality?
Это хороший вопрос?
7 Комментариев
Here's what I know so far:
-The phone appears dead after a screen replacement
- The shield flex that takes the home button flex is damaged.
- When connected to a pc, the phone appears on screen as a device (although with no screen to respond on, I cannot authorise access)
-When connected to a charging source, I get no signs of life via vibration when switching the mute button on and off.
- I DO get a small vibration response when I press the power button and the two volume buttons (diagnostic snapshot?).
Could the phone be stuck in some kind of state, and need a power/home button reset (which I can do when I restore the home button connection)?
из Lee Barnes
Just replaced the metal shield plate and reinstated the home button connection.
Still having the same problem.
из Lee Barnes
Does iTunes or 3UTools report anything about the phone being in recovery mode? Or for 3UTools normal mode as well?
из Ben
No sign of this unfortunately
из Lee Barnes
Can you upload a picture for the damage before buying anything?
из Rany
Показать 2 больше комментариев
