What 's the kinds of stones I can use and how can I drill it?
the process of friction is not so clear
please increase the length of it make it clear
Это хороший вопрос?
Счет 1
Добавить комментарий
3 Ответов
Выбранное решение
@kassab - Starting a fire without a match can be done many ways!
  • Flint and steel which is by far the easiest to carry with you when hiking.
  • Friction using two things that when rubbed at a high speed create heat. Often you don't have the needed parts or a means to create them to do this (which I think was your core question here).
  • Sunlight using a magnifier (to concentrate the light) which can be a lens made from glass or plastic or even use water! Using a sheet of plastic, a broken bottle or, even a shiny metal pan. Dependent on the Sun being available.
  • Chemical which creates a reaction of fire or high heat. Not very practical when lost.
In all of these you still need dry tinder & burnable items for fuel.
Был ли этот ответ полезен?
Счет 1
Take a bleeding heart liberal democrat and rub her up against a Republican. You'll quickly understand the concept of friction. Just ask my currently estranged girl friend if you can get her to shut up long enough to even get a question in..
Счет 0
2 Комментариев:
Sulphur Dioxide (Brimstone) and you don't want to drill it.
из
I had so many and such large stones in my kidney they drilled on it til it had to be removed!!!! Largest stone was bigger than a lemon .... Thank God they finally took it!!! Lol I wanted to add my thoughts .... Have a great and groovy day!!!
Счет 0
Добавьте свой ответ
seif kassab буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 19
За последние 30 дней: 40
За всё время: 773
