The first FWD car to be exported to North America by Volvo
fan is not running
i have a 1995 Volvo 850 series, 2.4 non turbo. My fan is not running either, the relay block has two yellow connetors in the middle, I know these are what control the low and high fan speed. fan test ok for running but when I ground jump the two center relay connectors for the fan speed the fan will not run, acts like there is no power getting to the relay block. thanks, Ken
Это хороший вопрос?
Оценка 1
Добавить комментарий
Ответов (1)
Выбранное решение
@fathertime24 not sure what you mean by ground jump the two center relay connectors . checking the wiring diagram for your Volvo these do not go to ground and shortening those to ground most likely will not accomplish anything. If anything applying a jumper from B1 to B2 on the relay would bypass the control module.
Был ли этот ответ полезен?
Оценка 2
Добавьте свой ответ
ken будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 302
