The Summer Infant 3D Lite is a stroller that features an ultra-lightweight design and easy storage capabilities.
8вопросов Показать все
Replacing the foam grip on handle
My dog chewed off the foam handle. How can I find and replace it?
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Выбранное решение
steph24w , Did a search for replace foam grip for your stroller and had no luck. I had similar issue with my lawn mower handle where the foam grip had deteriorated. To repair it I went to the hardware store and bought a 6 foot length of foam pipe insulation $1.50, cut it to size to fit my handle(it already has a open seam) so I slid it on and then wrapped the foam with electrical tape to keep in place and reduced the size a bit for comfort. You could do both sides to match. The foam can also be bought as a tape roll also. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
Был ли этот ответ полезен?
Оценка 1
Добавьте свой ответ
steph24w будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 7
За последние 30 дней: 33
За всё время: 1,854
