Apple Watch S1 - Force Touch Gasket Replacement & Adhesive
Is the Force Touch Sensor Gasket (38MM Series 1 Apple watch) from iFixit the only adhesive needed to replace the screen?
The original battery expanded to about twice its normal size and the screen and the force touch sensor gasket were pulled from the watch case in the process.
Это хороший вопрос?
2 Комментариев
Does your watch still functions normally even with the force touch sensor being broken?
из Koen Heemskerk
Can you tell me what size special screwdriver is needed to remove the touch screen sensor? Thx
из Scott Schaeppi
