i think JBL xtreme cons is the battery life.
so far replacement xtreme that best buy tampa gave me is working fine, but i have to be prepared to buy the replacement battery.
by the way, out of the topic, i auditioned xtreme side by side with Bose revolve +, I almost exchange the JBL over to Bose but the verdict is; "xtreme is still the xtreme" in terms of sound. its just JBL xtreme gave me that loud and clear output compared to bose, plus the JBL's stereo dynamic effects.
though BOSE did sounded 360 deg. means anywhere you stand, you get the same audio output but the sound is "mono", anyways what do we expect from a BOSE full range single driver right?
anyways back to JBL, i hope xtreme will always have a replacement battery available anytime just in case, the issue of battery life occurs.
Был ли этот ответ полезен?
Проголосовали
Отменить
Оценка
Отмена
Scroll through this thread to find the appropriate place for this comment. Then, click "Attach comment to this post" to move it.
6 Комментариев
Went to Best buy Tampa today. 4/30/17 they replaced my Red Xtreme.
cross fingers hope this one wont have anymore charging problems.
draining the battery as of now totally, before initial charging.
из Johann
Dear Johan I’m facing the same problem with my new jbl extreme , the 5th lamp is still blinking although I’ve been charging it for more than five hours , seeking your support to know whether it stopped blinking in the new one they gave to you or it’s normal that way ?
Thank you in advance
из Mina
If the speaker never finishes charging, ie: the 5th batter indicator led never stops flashing then your battery is bad and will get worse overtime. Happened to me, jbl refused to repair it for me so i had to do it myself using a guide on this site.
из maxspeed3006
I finally got it figured out! Everyone facing the problem when 5th led is blinking, and then it goes back to the 4th led blinking, no worries, your xtreme is fine, it's just the latest update that has messed up the lights themselves. I have tested with two xtremes, one with the new update( the one that enables choosing play button as Google assistant/ Siri) and another with the outdated software. The updated version had the above mention charging problem, while the outdated was not. The minute I updated the other xtreme, it started exibiting exactly the same charging problem, making the update the only culprit here. Both speaker have no problems with playing time - at least 14 hours or even more of continuous play. So the new led meanings : 5th led blinking - speaker still trickle charging; 4th led blinking afterwards - speaker is fully charged.
из Jancukas Puncukas
My JBL extreme is stuck blinking at the 4th led an I've been charging it for a wholeday now an I'm afraid it's broken any advice?
из Jonathan Boodhoo
Показать 1 больше комментариев
