The HP LaserJet CM1415fnw is a multifunction color printer produced by Hewlett Packard.
19вопросов Показать все
Printer misses information on page or isn't transferring info
My printer has started to make a very loud crinkling noise and is missing part of printed field. Most recent document was only 40% visabje and not all aligned. In inspecting the rear opening, there is a very loose and damaged plastic sheet/roller cover that I see.
Can it be fixed?
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Выбранное решение
@dgpagel ,Doug, 1st link is the HP support site where you may find a authorized service/support. 2nd link is a site that sells HP replacement parts and if you see the plastic sheet/roller you require for replacement click on it and a exploded parts view will come up which may aid in the installation if you want to attempt the repair. Tried to get you a free service manual, the 3rd link is to be your manual but when I downloaded it came up as 1410 model, may be the same, not sure and the 4th link wanted $5.00 for service manual. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
http://www8.hp.com/us/en/store-finder/in...
http://www.printerworks.com/Top-LaserJet...
http://www.feedroller.com/store/Service%...
http://copynews.net/hp-color-laserjet-cm...
Был ли этот ответ полезен?
Оценка 1
Добавьте свой ответ
Doug Pagel будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 4
За последние 30 дней: 4
За всё время: 75
