After dropping Samsung Galaxy S7 screen is black
Hi,
I have Samsung Galaxy S7 SM-G930F phone which has been dropped and has a cracked outer glass (at least it seems it is just the glass but not the LCD). It is still recognized by the computer and top LED and bottom buttons are lit except that the screen is totally black. I thought it is firmware issue so I tried all those combinations to hard reset it , get into recovery mode etc. I even tried to flash stock firmware. But it still remains black. So my question is what are the chances that the actual LCD panel is damaged. But I have never seen a damaged LCD which does not show any signs and just stays black. Usually it shows something even though it is cracked. Thank you in advance.
Это хороший вопрос?
2 Комментариев
Is there a way to recover the data on the phone if the LED is damaged?
Can it either be hooked up to a PC or another phone to move the data without
the primary phones being lit?
из Andy
I have one too same with Karolis but when my phone was dropped last June 2020, it developed a rainbow on the LCD, minutes after the screen went black. I removed all sim cards as well as the micro sd card just as it went black. I am trying to fix or get a hold of this now April 06 2021 and I can still see the dot sensor that changes light (from green, blue to red) whenever I charge it. My question is that if I were able to repair the phone will my data such as messages, contacts, files, and images be there still? or it will automatically erase all the data saved on the device?
из Jay Zee
