Repair information and disassembly guides for laptops manufactured by Haier.
120вопросов Показать все
My laptop is not connecting to any Internet.
I have hair i3 prime minister laptop. It is not connecting to any WiFi or evo net. It is actually connected but it's showing 'no internet, secured'. My WiFi is working on other cell phones, only my laptop is not working the same internet. Please help me with it.
Это хороший вопрос?
Оценка 2
10 Комментариев
Have you tried to restart it?
из
Try connecting through ethernet
из
You need to find out whats going on before making an answer
из
Exactly. This troubleshoots it. The goal is to see if it is the computer's WiFi chip's connection or the router.
из
then make this a comment. troubleshooting steps are comments. Answers are when you know whats wrong and how to fix it.
из
Показать 5 больше комментариев
Добавить комментарий
2 Ответов
Выбранное решение
If your computer connects to the WIFI but shows no internet connection then check the name and password you used. Check to see if the connection is automatic or if it needs to be set to a particular protocol. You can also try deleting the connection, rescan and connect to it again. Also, try updating the drivers for the wireless device.
Был ли этот ответ полезен?
Оценка 4
Hello,
You may find your solution here on internet connectivity on your laptops.
https://www.buytvinternetphone.com/blog/...
Moreover, once I got an issue on my internet connection so I called Spectrum Customer Service and with in no time, they resolved my issue. So i would recommend you to check your internet connection to make sure if its working completely fine.
Оценка 0
Добавьте свой ответ
pirh khan будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 7
За последние 30 дней: 19
За всё время: 9,338
