Hot air blows thru drivers side and cold air on passenger side
2007 Honda Accord sedan air is hot on drivers side, cold on passenger side.
Это хороший вопрос?
Это хороший вопрос?
Non dual control.
There is a cable fault or something has become detached or worn.
Dual control.
There will be a fault with the motor which drives the air direction flaps.
Both means that someone will have to pull apart some of the dash to get to these control areas.
Был ли этот ответ полезен?
Here’s a couple of videos on how to fix it:
https://www.youtube.com/watch?v=w-NX26kn...
I have a 2004 Honda Accord Coupe EX my AC blows hot I put freon in it the compressor works fine everything is good but just does not blow cold what do I do
so what should i do I have a 2004 Honda Accord Coupe yes my AC does not blow cold and both hot it has freon compressor is fine everything is good don't know what to do
За последние 24часов: 4
За последние 7 дней: 28
За последние 30 дней: 97
За всё время: 665
is the driver temp dial hot and the passenger temp dial on cold?
из Cameron
I have this problem too and the car does not have dual controls.
из Daniie W
I have this problem on my 2007 accord with dual control. I turn the driver side down to low which is as low at it can go and after one minute I turn it back up and seems to work find
из Matt walsh
