Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Дата выхода 25 сентября 2015 г. Модель A1688 / A1633. Ремонт данного устройства схож с предыдущими моделями, требующий отвертки и инструменты для вскрытия. Доступен в версиях GSM или CDMA; с 16, 64 или 128 ГБ памяти; в цветах: Серебристый, Золотой, «Серый космос» и «Розовое золото».
2385вопросов Показать все
iPhone 6s battery draining fast even after replacement battery twice!
Hi ,
Guys I replace my battery because it was draining fast
but I notice it still draining fast , better than original battery but still draining fast
so I was thinking maybe the new battery is defective
So I replace battery again
and still it's draining fast !!!
What is the problem ?
Is there something else will make my battery draining fast ??
Отвечено! View the answer У меня та же проблема
Это хороший вопрос?
Оценка 5
Добавить комментарий
3 Ответов
Выбранное решение
Hi,
Been using cheap cables I guess?
You have damaged the tristar chip, when this is damaged, it can drain the battery extremely quickly.
You would need to take it to someone who does microsoldering, and can replace the tristar chip. :-)
Был ли этот ответ полезен?
Оценка 4
Комментарии:
I never ever used a cheap cable , I used the original cable came with iPhone
из
Any liquid damage? Any recent drops? Charging in car? So you've never ever used a friends cable when you haven't got yours?
из
I always have a cable with me , I use I power bank from Anker
the same power bank I used before iPhone 6s , I never have problem with battery on my old iPhone
and no there isn't any liquid damage
BTW my iPhone 6s had a problem with battery that Apple talk about
https://www.apple.com/support/iphone6s-u...
But in my country there isn't apple store
из
Is IC or U2 or Tristar is different name but same chip ?
из
Yes basil same chip.
из
Показать 5 больше комментариев
Hi, I still have the same issue even after new battery and IC replacement. Is there anything else that can have the problem?
Оценка 0
I buy a lot of iPhone aftermarket batteries. I estimate that 25% are “poor” when new. 75% are “very good to excellent”.
I was buying great batteries from a specific vendor, and suddenly they changed suppliers I ended up with a bunch of duds that couldn’t hold a decent charge. So beware that someone else’s experience with a vendor may not be the same as your experience.
Similarly, not all battery adhesive strips are the same. Some are good, but some of these adhesives are made so poorly that you’ll never be able to release them properly. I got a batch of bad adhesive, and battery re-replacement became a huge time sink as I spent far to much time trying to release the battery, followed by more time trying to remove the sticky remnants of the lousy aftermarket adhesive.
Оценка 0
Добавьте свой ответ
Basil будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 13
За всё время: 4,049
