Repair manuals and support for 4-wheeled passenger and cargo vehicles.
7434 Questions Показать все
Why does radio remain on after ignition shut off in 1999 Saab 9-3?
1999 saub 93 convertible: ignition turned off but radio remains on.
Отвечено! View the answer У меня та же проблема
Это хороший вопрос?
по рейтингу 3
Комментарии:
Does it turn off when you open the door? If so that's considered a feature so you can listen to the end of a song when you shut off the engine--my pickup does that. +
от
So does my Caddy
от
Добавить комментарий
Комплект инструментов для замены батареи Macbook
Доступно с $69.99
Buy Now
Доступно с $69.99
Buy Now
4 Ответов
Выбранное решение
Yup, it's by design. It's so that you can keep listening even when the engine is turned off
Был ли этот ответ полезен?
по рейтингу 2
Комментарии:
My truck does the same thing--its a feature. +
от
I suppose the radios power lead is directly wired to the battery current. Find a cable that is triggered by the ignition (e.g. the lightswitch) and wire it to that.
по рейтингу 1
A piece of metal covering over the key hole has maybe been pushed inside the ignition. It causes the car to act as if something has been left on. It does not run the battery down but have to manually lock the doors.
по рейтингу 0
The Saab has an ignition switch in the center section of the transmission/handbrake area. Over time, this gets dust into the mechanism and when the key is removed the ignition no longer pops up. This is a very common problem with Saabs, especially the 93 and 95.
You can try jiggling the key to pop it back out. If this does not work, you could also try blasting it with some compressed air and then applying some WD40. Usually that will fix the problem.
по рейтингу 0
Добавьте свой ответ
Liz будет вечно благодарен.
Просмотр статистики:
За 24 часа: 0
За 7 дней: 3
За 30 дней: 35
За всё время: 2,942
