Known as the ''PS2'', it is a sixth-generation video game console first released by Sony in Japan in March 2000. The United States saw it later in 2000 with the SCPH-30000. Repair of this device requires only common tools, but can get tricky.
189вопросов Показать все
PS2 Slim making a grinding noise
So my PS2 is making the exact same noise as in this video:
https://m.youtube.com/watch?v=4Z2gR3gKFr...
and according to this video it's the Worm thing. Now I have not taken my PS2 apart to check that worm thing, but it is making the exact same noise and only does it when a disc is inserted just like in the video so I assume it's the exact same problem.
Do I have to buy the replacement part and have someone replace it for me? Does Sony still do repairs on PS2? Or is there a home fix I can do?
I just got Okami for ps2 so really eager to get my ps2 up and running again.
Это хороший вопрос?
Оценка 1
Добавить комментарий
2 Ответов
If you think you can do the repair yourself i would recommend you to do it. The reapair isnt that hard and shouldnt take that long and i also dont believe that sony does still do work on the Play Station 2's anymore
Был ли этот ответ полезен?
Оценка 0
1 Комментарий:
Deven - do you know how much a new one of those worm things cost?
I normally buy off Amazon
из
If the laser moves up but it doesn’t spin while making a grinding noise it’s because the 2nd contact isn’t touching. https://youtu.be/7a2JV6q134k
Follow his instructions, worked for me.
Оценка 0
Добавьте свой ответ
Gray Wolf будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 28
За последние 30 дней: 90
За всё время: 4,637
