The PowerMac G5 is a desktop computer first produced in 2003 by the Apple Corporation. This guide will review the repair process of an Apple PowerMac G5 model number A1047 EMC 2061 from 2004. It was discontinued in 2006 as part of the Intel switch first to developers then consumers.
194вопросов Показать все
How do I repair these power supplies
There was a know issue on these power supplies but I cannot find what it was. Here was the Apple recall which has expired: http://www.apple.com/support/powermac/po...
I have several units I would like to repair. I know they can be sent off for repair. Any ideas?
Это хороший вопрос?
Оценка 3
1 Комментарий
I'm still looking for an answer to this one.
из
Добавить комментарий
1 ответ
Выбранное решение
This looks like it could be what you are looking for. http://jimwarholic.com/2008/11/apple-ima... and here is a nice alternative repair of the power supply. http://damntechnology.blogspot.com/2009/... Good luck and let us know if this what you were looking for...
Был ли этот ответ полезен?
Оценка 5
3 Комментариев:
Thanks for the try. Those links are about the G5 iMac not the Power PC G5. I've talked to Jim Warholic on this problem and he didn't have an answer
Turkey - I usually don't ask easy question ;-)
из
Ain't that the truth
из
I always forget about all these Mac's being different I always think that there would be some sort of standard :-) So I learned that the G5 and the Power Mac G5 are using different power supplies, correct? Looks like they must be made out of platinum to explain the high cost (I love my cheapy ATX power supplies :-) Now you mentioned Power Mac and Power PC in your comment. Are those interchangeable terms, I mean is this still the same thing or a totally different animal altogether?
из
Добавьте свой ответ
mayer будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 4
За всё время: 1,568
