Released September 16, 2016. Models A1661, A1784, and A1785. Available in 32, 128, or 256 GB configurations in Rose gold, gold, silver, black, jet black, and (Product)Red.
794 Questions Показать все
Why does home button not work on new screen?
I replaced the screen on a iPhone 7 Plus and everything on the screen assembly works except the home button now. The home button does not seemed to be damaged. Everything worked before the screen replacement. The screen was shattered to the point that the lcd was broken so I'm not sure if that kind of damaged could of damaged the home button.
Отвечено! View the answer У меня та же проблема
Это хороший вопрос?
по рейтингу 1
Добавить комментарий
PC Laptop Batteries
An easy fix for a big power boost.
Купить сейчас
PC Laptop Batteries
Купить сейчас
1 Ответ
Выбранное решение
Could be an issue with the New Screen, if the cables are damaged of faulty then the home button just completely stops working even if everything else on the device is fine (found this out the hard way when removing a screen to do a new rear camera). Unfortunately you can't test this by trying a different home button to see if that also fails on that screen(which would be fairly cheap) because only the original button works in any capacity on the 7's so you'll probably need another screen to test.
Был ли этот ответ полезен?
по рейтингу 0
Комментарии:
Thanks. I tried a new screen and the newer one worked.
от
Добавьте свой ответ
Carlos Ramirez будет вечно благодарен.
Просмотр статистики:
За 24 часа: 0
За 7 дней: 0
За 30 дней: 1
За всё время: 141
