The Wii Remote is the original, primary controller for the Nintendo Wii game console released November 19, 2006. The model number for the original Wii Remote is RVL- 003.
21 Questions Показать все
Cables snapped! Please quick help!
I accidentally snapped the red aire of the speaker! What i am going to do now to fix this!
Комментарии:
Oops, i mean wire. The keyboard changes the text.
by
Add a comment
Android Fix Kits
A new screen or battery is one kit away.
Купить сейчас
Android Fix Kits
Купить сейчас
2 Ответов
Chosen Solution
You will need to solder it back on, just take off about 3mm of the rubber casing of the wire and heat it up until it melts.
Score 2
Комментарии:
When soldering you do not melt the wire ^_^
You need to use new solder to solder it back on.
by
@neotil i didnt mean the wire casing, i meant the solder.
by
Add a comment
If you want a proper fix, and don't have a soldering iron or the courage to try, the cheapest way is to find a local electronics repair shop and ask them to resolder it for you. They should have a minimum charge, but for such a small job - it should be possible to simply have it done on the spot and get you going.
To repair this, with a soldering iron, you could attempt to gently reheat the solder just enough to melt the positive red speaker wire back into the existing solder.
Or to redo the job, with some some solder wick, you would heat the existing solder for the red (+) wire with the wick placed in between until it melts and gets soaked by the wick. Ensure the connection surface is clean, or gently wipe with some flux to prepare to solder the red wire, and simply resolder it.
Not having the actual tools for a small job is likely to be cheaper at a repair shop, given that the person is honest and does not charge a whole lot for a few minutes of work, again I would expect a minimum 1hour charge but no more.
Add a comment
Add your answer
Santi12008 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 88
