Digitizer not working after LCD replacement
I installed an iPhone 6 Plus LCD today and everything seemed to be functioning normally until I tried to set the phone up. The touch screen didn't work. I tried reconnecting all of the cables multiple times but this didn't yield any results. Could I have done something during the repair or is it a faulty cable?
Это хороший вопрос?
4 Комментариев
Could be a damaged FPC connector for digitizer touch screen cable on logic board or a defective screen usually.
Did the old screen have display and touch screen at least working?
Hopefully it isn't touch ic chip at fault as that requires microsoldering and costs quite a bit to get it replaced.
из Ben
Like Ben said, i'll note that i opened it up while it was on and unplugged the homebutton back flex, and all of a sudden it started working and i plugged it back in and it stopped working. So i'm doing a restore right now and if that's not it, then its the back flex cable guys!!! another resort than getting the touch ic chip fixed. - LoKi
из passthex12
Ever get it working? Thought I had a faulty display assembly (figured as much cause I found it at a garage sale for free. I ordered a brand new one and to my surprise, still no digitizer :( I inspected the tiny pins on each connector with a magnifying glass carefully and they all look instact and perfect...
First time this has happened out of the 50+ display assembly replacements I've done.
из Andrew Christiansen
That's touch ic gone bad on your one.
из Ben
