The 7" version of Amazon's new high-end tablet series, released in October, 2013. Model C9R6QM.
I got my kindle fire wet and now it won't come on
I got my kindle fire wet and now it won't come on and stay on.
Это хороший вопрос?
Счет 0
Добавить комментарий
2 Ответов
Выбранное решение
yovonna38, Stop charging or powering up your device until the liquid damage is addressed correctly, as you could be shorting out components inside the Kindle. You really should take care of the corrosion that is happening inside the tablet from the water damage as that could be your problem. A tear down link for your device Link #1, disassembly guide will enable you to get inside the Kindle to remove the damage/corrosion caused by the liquid. Use the 2nd link as a guide/instruction on how to clean/repair the device from liquid damage. After this you will be able to power on the phone and see if further damage has to be addressed. Good luck.
Kindle Fire HDX 7" Teardown
Electronics Water Damage
Был ли этот ответ полезен?
Счет 2
buy warranty verify product # serial number
mostly does not come with warranty , open whole tablet with Check with laser light check to see if any water mark identify mark spot then open “FLAT PIN WITH NARROW POINT” wipe with alcohol
Счет 0
Добавьте свой ответ
yovonna38 буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 2
За последние 30 дней: 14
За всё время: 6,727
