Дата выхода 19 сентября 2014 года. Это маленькая версия iPhone 6 Plus с 4.7-дюймовым экраном.
4563 Questions Показать все
iPhone 6 stucked in apple logo after replacing u2 ic
Hi. A customer brought to our store an iphone 6 dead after plugging in car charger. I replaaced the u2 ic and it started charging with the correct voltages but it just stucked at logo and wont go further. I see no short and the mainboard doesnt heat. It didnt fall to water. The voltage going into battery is between 3-4.xx help pls. The client doesnt want to lose his inforrmation.
Actualización (25/05/17)
I did it maany times now. Same result. The voltage is ok tho in the baterry conector from the board. If the u2 is placed incorrectlly it will just dont charge or the voltage in that conector should be less that 1v
Отвечено! View the answer У меня та же проблема
Это хороший вопрос?
по рейтингу 0
Комментарии:
My friend the probllem is that the cliennt wants his information back. All he wants from the. Iphone is the information
от
Добавить комментарий
Free shipping on all orders over 100,00 $ or containing a Pro Tech Toolkit!
Посмотрите наш магазин
Ever fixed something? That’s Genius.
Share your repair story with #ImAGenius
We Are All Geniuses
3 Ответов
Выбранное решение
I would first repeat the chip replacement since this can occur after a bad Tristar chip replacement.
Был ли этот ответ полезен?
по рейтингу 6
Комментарии:
There are many other things that can be wrong. One of them simply being the data is corrupted and you need to update or restore (and loose data). Can you connect to ITunes?
от
That's good to know. @rany I got a 5S boot looping and flashing red screen. Definitely water damaged. But I'll be glad to try the u2ic before anything else
от
You'll need to disconnect front cam, fit a known good battery, make sure gas gauge is attached, replace Tristar, and restore from DFU.
от
hi friends i have iphone 6 full short after change u2 ic please tell me solution
по рейтингу 0
If you have between 3v and 4v and only apple logo, the U2 chip is not soldered well. It helps just to reheat it better to solder all balls. BR
по рейтингу 0
Добавьте свой ответ
Jackychang будет вечно благодарен.
Просмотр статистики:
За 24 часа: 2
За 7 дней: 12
За 30 дней: 70
За всё время: 1,657
