Шестое поколение iPhone компании Apple, представленное 12 сентября 2012 года. Ремонт данного устройства схож с предыдущими моделями, требующий отвертки и инструменты для вскрытия. Доступен в версиях GSM или CDMA; с 16, 32 или 64 ГБ памяти; в Черном или Белом цвете.
2522вопросов Показать все
Rear Camera black screen
The Rear Camera of the phone goes black screen.
I used it ive take a pic so fast i mean rapidly the half of the camera app goes purple and crashes then when i opened it it goes black screen
Note:I tried the low power mode trick it works then it happened again i tried it again and it not works anymore
The phone has a bad battery .Is it a possibilty of bad battery ?
Or a bad rear camera ?
Это хороший вопрос?
Оценка 1
Добавить комментарий
1 ответ
Выбранное решение
I think it is the rear camera. A bad causing under voltage would cause more trouble like a unresponding or ghosting touch screen. Replace the rear camera first. This was a very common problem of iPhone 5 that the rear or front camera stops working and causes crashes of the camera application. If this doesn´t work out please post your results so we can check the next steps.
Use this guide Замена задней камерыiPhone 5 and good look to you.
Был ли этот ответ полезен?
Оценка 3
28 Комментариев:
luck not look
из
Ok sir .i will get my replacement rear and battery tomorrow i update you as soon as i replaced it .I cant touch the phone sometimes when the phone is not being used for a long period of time .For example when i will sleep at night when i power it on the phone is not responsive i just close the phone and open then it will respond .
из
And i have a question about the steps is it okay not to remove the battery from the housing i mean i will just unplug the cable of battery to the board ?
из
yes, it is no necessary to separate the battery from the rear housing. But the first thing you should do when your opening any phone: unplug the battery first before unplugging anything else! This will avoid any kind of shorts during the disassembly.
из
Ok sir another question sorry for asking so much i really wanna learn fixing phone that much .what if it shorts ?For example the rear camera shorted what does that mean is that means that the rear camera is damage or the board is damage ?
из
Показать 23 больше комментариев
Добавьте свой ответ
Fixie будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 10,111
