Why are my clothes coming out of washer with bleach spots?
Some of my clothes are coming out of the washing machine with bleach spots that match the pattern of the washer tub (small holes on tub wall). This has happened even two or three cycles after I washed whites with bleach.
Это хороший вопрос?
5 Комментариев
Hi Laurie Lien, are you adding the bleach to the water after it fills or to the bleach dispenser?
из Blake Klein
acne-targeting products, like Clearasil and Proactiv, contain benzoyl peroxide. The ingredient acts like a bleach on textiles
из mayer
You can also use Oxi products and not chlorine bleach.
из Whole Witt
Washing machines are getting weird now,
where some new world order is only letting
enough water in to get articles wet, and no more.
I found this situation at friends facility helping
Elderly, and was shocked at this nonsense.
If that's the case, what was normal adding bleach
is now overkill.
This is also a great process perfect for iPad to phone
apps, using the timer to alert when events need attention.
Sitting too long in tub is exposing articles to air at the vent holes in tub.
This changed chemical action still active while wet.
Good luck..
из Philscbx
Let's call in a pro one this one @ladytech , there are others on Google that have had the same problem but no real answers.
из mayer
