MBP Late 2016 — Butterfly keyboard's key double hit problem
I recently got a new Macbbook Pro. Problbem is what you're exactly seeing here and it's specific to the bb key.
I touch it once and it puts two b characters for me most of the time, but not always. This key is much looser and more sensitive than the others.
Suggested by @pydev, I removed the key cap. It does work flawlessly without the key cap. But when I put it back, same old story.
Any ideas?
Update: Here's a software solution working around the problem.
Update: Apple has announced a MBP Late 2016 — Butterfly keyboard's key double hit problem for macbooks with butterfly keyboard.
Это хороший вопрос?
22 Комментариев
Have you spilled anything on it or has it has an impact?
из mayer
No, not at all @mayer.
из Sepehr Lajevardi
I'm experiencing this issue as well!
из Nont Banditwong
I'm experiencing this very thing. I noticed that when I tested it out in Microsoft word, I just typed in B again and again until it doubled.
I tried to press the button with the same intensity each time, and sure enough, after the 3rd try b bb << (Second attempt there) it automatically populated as double-b... I'm not sure how to explain this in CPU terms. But it seems to be a key that is out of whack in general throughout the OS.
Would love to hear if there's a solution and how customers can update our CPU's.
Cheers,
из thomasbunn423
thomasbunn - You'll need to bring your system in to an Apple Store for them to replace the keyboard. There is a known issue within the first gen units.
As far as upgrading the CPU sorry guy no can do! Apple uses soldered CPU's & RAM in all of their current laptops, you can't swap it out.
из Dan
Показать 17 больше комментариев
