A treadmill is a device for walking or running while staying in the same place.
35вопросов Показать все
Why does my New Balance 1500 treadmill turn on and shut right off?
I was running on my New Balance 1500 treadmill and when I went to turn down the speed, I got shocked. At first it was like it froze up and just stayed on the speed I was at and then after a few minutes it just shut off. When I say shcoked I mean as in the way when you walk on carpet and then touch someone, that shock. I went through the manual and did everything they suggested, called New Balance (still waiting for a call back), left unplugged for a whole day and nothing works. When you first plug it in, the light comes on but then the machine just shuts right off. It's like it ins't connecting in the deck part, the area where you press power and speed and all that. Can anyone help me, please.
Это хороший вопрос?
Оценка 1
Добавить комментарий
3 Ответов
Наиболее полезный ответ
Sounds to me like your ground wire on your wall jack may be incorrectly wired. I'd get a socket tester at my local hardware store ( about $5) and test it before going further.
Был ли этот ответ полезен?
Оценка 1
you have a short to ground and need the motor controller replaced.
Оценка 0
There could be several reasons your New Balance 1500 treadmill is turning on and then shutting off immediately. Here are a few things to check:
  1. Ensure the safety key is inserted correctly and seated in the console. The safety key is a safety feature that shuts off the treadmill if it is removed.
  2. Check the power cord and outlet to make sure they are functioning correctly. If the outlet is not getting power, the treadmill will not start.
  3. If the treadmill has a power switch, turn it on.
  4. If the treadmill has a reset button, try pressing it.
  5. If none of these steps fix the problem, the issue may be with the treadmill's motor or control board. These components can be challenging to troubleshoot and repair, so you may need to contact the manufacturer or professional repair service for assistance.
(Find More creative solutions)
Оценка 0
Добавьте свой ответ
Dawn будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 3
За всё время: 1,700
