Model A1502 / 2.4, 2.6, or 2.8 GHz dual-core Intel processor / Released October 2013
552вопросов Показать все
Won't turn on even when the MagSafe is plugged in.
Won't turn on even when the MagSafe is plugged in. This is a new MagSafe that had been working. Laptop just stopped working. Is this a hardware issue that could be repaired?
Update (06/08/2017)
It is a ME864LL/A 128GB. I am not aware of any water and or drop damage. I have the back off and do not see any obvious signs. The MagSafe MD565LL/A was from the Online Apple Store and was bought 8/16. This is happened this spring not prior to new MagSafe. There is a thought that it could be the part on the inside of the computer that the MagSafe connects too. I look forward to your reply.
Это хороший вопрос?
Оценка 1
1 Комментарий
Please give us your exact model as they have been making these sine 2012. Please tell us the history of malfunctions including any spills and impacts. Seems like you bought a new mag-safe, was the same thing going on with the old one. Is the new one Apple branded or a knockoff?
из
Добавить комментарий
2 Ответов
Выбранное решение
Here's how to replace the mag-safe board: MacBook Pro 13" Retina Display Late 2013 MagSafe DC-In Board Replacement
Here's the replacement part: MacBook Pro 13" Retina (Late 2013-Early 2015) MagSafe 2 DC-In Board
MacBook Pro 13" Retina (Late 2013-Early 2015) MagSafe 2 DC-In Board Изображение
Продукт
$14.99
Был ли этот ответ полезен?
Оценка 2
When you plug the MagSafe adapter in, you should see a green light come on the connector. If not, try it on another Macbook. If it works, then probably the MagSafe port on your Mac is probably bad.
Оценка 0
1 Комментарий:
How do I replace the port on the Mac? I do not have another Mac with the same type of connector to try on another Mac.
из
Добавьте свой ответ
Mary Brown будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 178
