Дата выхода 19 сентября 2014 года. Это большая версия iPhone 6 с 5.5-дюймовый экраном.
1525вопросов Показать все
There is a discolored spot in the middle of screek when it's popped in
I'm repairing a 6 plus, and it has a discolored spot at the top of the screen, a little to the right. I tried loosening the earpiece bracket screws since I've heard this can cause discoloration but it didn't help. The discoloration goes away when I test it before closing it up, but once I pop the screen down into place it shows up again. I'll be grateful for any help.
Это хороший вопрос?
Оценка 0
Добавить комментарий
2 Ответов
Наиболее полезный ответ
Try removing the upper left screw of the plate holding the lcd/digitizer/camera cables. It normally do the trick.
Edit 13/06/17
Look at the flex bend (Red Circle) and at the metallic part (Blue rectangle) if they are properly sitted , this should be under the metallic backplate of the screen.
Был ли этот ответ полезен?
Оценка 1
1 Комментарий:
It didn't work. Think it may have something to do with the shield plate maybe? I moved everything over to another LCD and had exact same problem but couldn't see anything obvious that'd cause it. Strange...
из
Do you have the ability to try a different glass/lcd, so that you can isolate this to a part issue or a board issue? Also, make sure there is nothing out of place on the device that could add a pressure point causing the discoloration.
Оценка 0
Добавьте свой ответ
Garrison Bates будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 2
За последние 30 дней: 2
За всё время: 47
