My front load washer isn't powering on - How to diagnose?
My Samsung front load washer (wf0500nce) suddenly wouldn't turn on - press the power bottom and nothing happens - no lights, no life.
The outlet, the plug and the cable are all fine. I took out the door switch and tested it for continuity and that checked out (although i am not sure if there being continuity means door switch is OK). I manually depressed the spring loaded switch to simulate the door being closed but it still wouldn't turn on.
How do i go about finding the fault?
Update (06/09/2017)
Is this the fuse?:
https://i.imgur.com/LJde7hq.jpg
https://i.imgur.com/s0NJOsd.jpg
Update (06/09/2017)
I don't see any fuse from noise filter to board. I do see what i think is the fuse in the board. I circled it in the picture. Sorry my phone's camera isnt the best.
https://i.imgur.com/Bd2h65G.jpg
Update (06/09/2017)
Yes oldturkey03, I am not showing any voltage on the relay you marked in the picture above. No 125v, no 220v...just 0.
Do you think it could be the fuse at the board that's blown?
https://i.imgur.com/vhZvFZJ.jpg
EDIT: Just found the diagrams:
Это хороший вопрос?
10 Комментариев
Kato x hard to make out but it is possibly a fuse.
из oldturkey03
Any idea how i can test the fuse? I can't just take it out because its put on with some kind off putty/glue seal.
из Kato x
No more ideas?
из Kato x
Did you figure this out? Same problem with mine.
из rezilient
Holy $@$*. Nobody has an answer. WTH???
из James Folger
Показать 5 больше комментариев
