First-generation Apple iPad with 3G capabilities. Model Number A1337. Available with 16, 32, or 64 GB of storage. Repairs are straightforward and do not require heat.
71вопросов Показать все
IPAD Storage space increase
Hi there.
Where is the storage for the IPADs? How can I increase the chip and put in more storage space?
Это хороший вопрос?
Оценка 1
Добавить комментарий
3 Ответов
Выбранное решение
You can not directly upgrade storage for any iPad generation. Upgrading the storage would require an external sd card but the iPad memory is only internal. Here might be the solution for you. It's an adapter for SD cards http://www.crunchgear.com/2010/01/27/app... Good luck.
Был ли этот ответ полезен?
Оценка 2
Another solution to this is using the new Goflex Sattelite wireless hard drive by seagate.
http://www.seagate.com/www/en-us/product...
500GB of extra space ;)
Оценка 0
Wireless drives are expensive. A cheaper solution is to store your videos and photos on an SD card with a special folder structure. With a connection kit these can then be transferred directly to and from your iPad. See http://www.ipaddvdtransfer.co.uk/ for more info.
Оценка 0
Добавьте свой ответ
Shaveen Bageloo будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 7
За всё время: 12,592
