Also called the Crosley Musician Entertainment Center.
Why has the sound stopped?
the sound has stopped all the functions are working but no sound
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Выбранное решение
msthang332001, Make sure the Line In Switch is in the off position if not using the Auxiliary Input, make sure the line-in switch, located on the back of the system near the auxiliary cable, is in the off position. It may be a bad volume switch/connection, bad speakers/connection, possible fuse blown for internal amp. if equipped or could be a faulty amp. The guide 1st link below will help get you inside the device to check/test components. If under warranty have repaired/replaced/refund under the warranty. Last link is Crosley support page. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
Crosley CR704 Speaker Replacement
http://www.crosleyradio.com/support
Был ли этот ответ полезен?
Счет 2
Добавьте свой ответ
msthang332001 буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 0
За последние 30 дней: 13
За всё время: 416
