Brand new Logitech UE Wonderboom NOT CHARGING
I bought my UE Wonderboom by Logitech 3 days ago and it does not charge. I'm traveling, therefore I can not go back to the store where I bought it from. I'm on an island so the warrenty isn't much use for me and I think I threw away the bill.
I saw this is a common problem with older UE's and there's many answers such as placing the speaker in the freezer for hours or pressing all 4 buttons at the same time for 20 seconds, but NONE of the "solutions" work.
Please help!!!!!!! I don't want to feel like I just wasted 100 dollars.
Thank you!
Отвечено! View the answer У меня та же проблема
Это хороший вопрос?
по рейтингу 0
Комментарии:
@zoefarah if you have absolutely no way of returning it etc. then there is no reason to worry about any warranty. The only thing you can do at this time is to tear it down and check the charging connector, as well as the battery. you might find a way to charge the battery by different means. Tear it down and take plenty of pictures and lets see if we can come up with a way to fix you up
от
Добавить комментарий
Комплект инструментов для замены батареи Macbook
Доступно с $69.99
Buy Now
Доступно с $69.99
Buy Now
5 Ответов
Выбранное решение
It might be a bad charger Vs a bad speaker. Are you able to get any response for the speaker?
Do you have a friend back home who can take it back for you to get it exchanged? If you do you could ship it, they will need the sales slip as well.
Был ли этот ответ полезен?
по рейтингу 2
Комментарии:
Yes!! It was the charger! I feel so silly for sticking my speaker in the freezer for hours haha! It seemed like the only solution. Kind of annoying they sold me a broken charger... but at least it's not my speakers!! :)
от
I thought i had the same problem but the plug actually just needed to be somewhat unnaturally/forcefully pushed further into the speaker which made me feel very silly, if you haven't already tried that :)
по рейтингу 1
I have the same problem, but I got no charger with my purchase. The only accessory I got was a USB-micro-USB cable. I've been using the charger fro my old Bose, and it does not work. Any ideas? Should a charger have been included. I had no parts list in the box. And that is unusual.
по рейтингу 0
Комментарии:
Sorry James for not seeing your question, it's always best to create your own so it is seen by everyone.
From the UE web site: WONDERBOOM It appears they only supply a Micro-USB cable.
I would recommend you try another charger
от
I only got a micro usb cable with my wonderboom & I just use my iPad charger plug which works fine. Have also used the charger plug from my Android & that works fine too.
от
How do you charge it is a light ment to turn on or what cause mine isn't charging and I only just got it
по рейтингу 0
Комментарии:
Check it isn’t the charger plug that’s causing the problem & make sure the cable connection is in the speaker properly. I use my iPad charger plug & also my Android plug also works. It maybe that it is already fully charged as mine was when I got it. Does it play at all? I find that the on light pulsates when charging & goes out when fully charged. Hope this helps.
от
I have one a month old and it already quit. I think I’ve used it 2x. It seems to charge with the cable it was sold with, & the light slowly blinks while charging and then goes out. But speaker does nothing….no power, no noise…..nothing. If I remember the power button is on top near the handle. I have the Wonderboom Ultimate Ears. Thanks in advance if anyone knows anything. Ronda
по рейтингу 0
Добавьте свой ответ
Zoe Farah C будет вечно благодарен.
Просмотр статистики:
За 24 часа: 16
За 7 дней: 109
За 30 дней: 493
За всё время: 14,747
