Руководства по ремонту и разборке Compaq Presario CQ60.
Compaq Presario CQ60 black screen issue
Hi,
I have a problem ... laptop screen is blinking and cut the picture frequently ...then I restarted the laptop...works fine but the fan spinning very fast and causes heat also...then after 3 days it suddenly shutdownn while i am surfing net...I started the laptop 2-3times power is on but SCREEN IS BLACK...why what is the issue....and I have cleaned the fan still it blows hot air why?... Please give me solution....please...soon as possible...
Это хороший вопрос?
Счет 1
1 Комментарий
Hello ,
Please give me solutions...
из
Добавить комментарий
1 ответ
Выбранное решение
Are the slots where fresh air is entering the computer clean? The symptoms are that those of the CPU or GPU are getting to hot and the PC is shutting down.
Был ли этот ответ полезен?
Счет 1
1 Комментарий:
Hi,
Problem with laptop issue is solved, mechanic had replaced the damaged graphic card and finally laptop works fine again... Thanks.
из
Добавьте свой ответ
Shakti буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 0
За последние 30 дней: 12
За всё время: 1,498
