Repair guides and support for your Sanyo TV.
360вопросов Показать все
Why is my picture not filling the whole screen on my new 50" sanyo
I expected to turn the TV on and the picture would fill the whole screen. There is 2 to 3 inchees around the screen that the picture does not cover. How is this fixed?
Это хороший вопрос?
Оценка 0
1 Комментарий
Your TV should have came with a manual, in the manual go to the picture/display settings section and it should explain how to achieve full screen display, etc..
из
Добавить комментарий
1 ответ
Выбранное решение
There are many causes for this. First things first, make sure your output device supports the aspect ratio of your new TV and is set to the resolution to the same as the TV. Make sure you don't have any cropped mode on, and that you aren't on a low resolution chanel. After you check these things, if the problem persists take some pictures and post them using this guide.
Hope this helps!
Был ли этот ответ полезен?
Оценка 1
Добавьте свой ответ
Mac G будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 4
За последние 30 дней: 14
За всё время: 2,091
