Repair and disassembly guides for desktops manufactured by Acer.
70вопросов Показать все
opening the am3400 case
I want to open the case of my AM3400-U2052 without a crowbar. So I can have a look around. My sound is sporadic and I suspect a poorly wired socket for the speaker plug or a poorly seated card. But first I have to look under the hood and the case refuses to come off.
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Выбранное решение
Tom Franczak, Normally there will be a couple screws to remove from the back that hold side cover, then slide the cover back a 1/4" to unlock from frame tangs and lift cover off. The link below is to a service guide(not your exact model) but will show side cover removal/instruction. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
https://www.manualslib.com/manual/232867...
Был ли этот ответ полезен?
Оценка 3
Добавьте свой ответ
Tom Franczak будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 124
